Re: Re: Re: '69 allis in great condition
MADDOG
10-31-2002 06:31:28
Huge Rear tires on the D-21 SII is ONE OF THE SECRETS to coupling all that 3500 series engine power to the ground. Look at the WIDTH of the (rear) tires on ALL the successful tractor pullers and you will discover the WIDER the tire, the more
HP you can apply to the ground. I run 33 inch wide REAR tires on my D-21 SII (she pulls 185 PTO on my calibrated dyno). This setup allow me to pull 10-18s inch plows in heavy SOD ground. At full throttle, this particular D-21 WILL PULL the FRONT END off the ground and it will STAY OFF the
ground until I reduce FULL Throttle. This D-21 weighs 18,000 lbs (yes, I've ADDED alot of metal to the frame in critical "places". When I rebuilt the engine, I added 400+ to the engine; in order for the bottom end (Crank, c/rods) to stay together.
