Cleaner needed for Allis G transmission.
AWB
11-03-2002 07:53:31
I have an Allis-Chalmers G transmission that needs a good cleaning prior to replacing the bearings and oil seals. Is there anything that I can soak it in for a week or two to properly clean it up? Thanks, AWB.
Tx Allis Man
11-03-2002 20:52:26
 Re: Cleaner needed for Allis G transmission. in reply to AWB, 11-03-2002 07:53:31
I have found that the cheapiest can of oven spray cleaner works real good for removing the gunk. I would not do this unless the transmission was taken completly apart. Hope this helps you out.
Don LC
11-05-2002 13:15:51
 Re: Re: Cleaner needed for Allis G transmission. in reply to Tx Allis Man, 11-03-2002 20:52:26
Try a product called "SIMPLE GREEN" you can get it at Meijer or WalMart store.....it is water base and does a great job on cleaning up military firearms stored in cosmoline.....
