//Allis Chalmer D-15 Industrial Backhoe Loader Tractor
Eugene Jurik
11-11-2002 08:14:52
Would like a breakdown of the Shuttle Clutch for I60 - I600 tractor. I also would need to know if there is a snap ring holding the front and rear chutch hub gear in position. I would like information on adjusting the rear and forward clutch shims. How do you adjust the clutch by removing and replacing the shim and in what sequence? Is it better to do this process of adjusting the clutch through the side plate opening or on the bench? I hope someone can help me with this information.
stephen Guriel
01-13-2004 05:37:26
 Re: //Allis Chalmer D-15 Industrial Backhoe Loader in reply to Eugene Jurik, 11-11-2002 08:14:52
I was lokking for a general price range for a Industrial d-15 backhoe. I would really appriciate it. Thanks
steveinct
11-12-2002 07:13:25
 Re: //Allis Chalmer D-15 Industrial Backhoe Loader Tractor in reply to Eugene Jurik, 11-11-2002 08:14:52
Eugene, I have an I-60 and I adjusted the shuttle clutch just before I put a new engine clutch in. It wasn't too hard. Best way is thru the access panel, put a big pan under it or drain it first, several gallons of fluid should be in there. The order doesn't matter, front or back. Just loosen the bolts holding the shuttle together and take out equal amounts of shims from all three stacks to get the gap to specs. I think the gap should be .040-060, I would have to check. It wasn't too bad. Now splitting the tractor to do the clutch with the loader on, that was not fun. E-mail me if you need anything else.
Terry Laidler
04-25-2005 18:18:08
 Re: Re: //Allis Chalmer D-15 Industrial Backhoe Lo in reply to steveinct, 11-12-2002 07:13:25
Do you have a pic ? I am trying to find out what model my backhoe is?
there is no numder on it i can find
except 05 23 66
it has the clutch that you talk about with the shims, it is diesel, water pump went it has just 1 bolt holding it on i need model numdber to order
Terry
inyone
08-03-2004 19:25:15
You say that you have (had) a I-60 tractor. You must had a front loader with it since you had to do the clutch and you mentioned that you had fun cracking it open. Do you still have the tractor? I ask, since I too have an I-60 and would enjoy knowing other I-60 owners. If you get this message, give me a response and lets chat about them Allis"s. :) David
David W.
04-26-2005 06:05:53
 Re: Re: //Allis Chalmer D-15 Industrial Backhoe Lo in reply to inyone, 08-03-2004 19:25:15
David, How many of the D15 backhoes were made? I'm planning on buying one tomorrow but have had trouble getting info on it. From what I can tell it is the D15 backhoe gas engine. David
