$500 D17
Trent Williams
11-15-2002 17:29:05
OK, Here's the deal. The guy says it's a Series 1, has an after market wide front end. He says it has combine wheels, ok rubber, grill is gone, transmission ok. He said the back of the cam (that drives the oil pump) is broken, needs new cam. He says he has a power steering pump rigged up to supply oil pressure to the engine, but he needs to keep the power steering pump. So, looks like it will require some work. I could buy it and resell, but I don't need it. It's pretty close to my hometown.
Greg Ballantyne
11-17-2002 17:39:15
 Re: $500 D17 in reply to Trent Williams, 11-15-2002 17:29:05
Depending on where you are, the price may seem high or low. Here in the MD. PA. area that could be considered a low price. I've seen tractors sell for more than that around here with stuck engines. I don't understand that myself.
Punchie
11-16-2002 15:46:49
Hi Trent
Where are you located at?
I would have to look at the oil, and make sure it is used for a little while and than think about it.
Punchie
Greg(Mo)
11-16-2002 08:30:13
I think he's asking about $400 too much! If he rigged something like the engine oil system, you're liable to find that tractor cobbed up from
top to bottom. JMO
