50/50 allis
Bert Davis
11-28-2002 10:59:37
I am draining transmission fluid into the engine, which is then venting throught the engine breather tube with loss of transmission fluid. This obviuosly is raising the engine oil fluid level.
Any ideas of the problem, and/or its solutions??
Thanks
Paul
11-28-2002 11:43:14
 Re: 50/50 allis in reply to Bert Davis, 11-28-2002 10:59:37
There are two pumps on the right front corner of the engine. The one to the rear is the hydraulic pump and is gear driven from the timing gears. It obiviously has a bad shaft seal and is allowing hydraulic oil to leak into the engine.
Don't know if you can get seals, etc. from AGCO or whether you will have to go to a bearing/seal distributor.
