Re: Re: Re: brake pins
David Maddux
12-20-2002 05:12:34
When talking about welding a nut on the end of the rod, what we usually do is weld a washer on the rod instead of the nut. It seems like you get a little better surface weld with a washer, then if you need to weld a nut over that. A lot of times you can turn the washer with a pair of vice-grips. But I know what you are going through you try everything in the book. Some times I feel like heating the whole tractor up in a bon fire . Dave
Tom
12-20-2002 16:51:24
 Re: Re: Re: Re: brake pins in reply to David Maddux, 12-20-2002 05:12:34
Go back in the archives and look for posts on this. The way I have done it and described it here is to drill and tap for a 3/8-16 thread. But you have to do it carefully and right. If you can't find posts about doing this ask here or e mail me. Basically you use a pipe or socket and a bolt and washers as a puller. But if they are really stuck there is more to it than this. And this is faster than pulling the final drive and axle housing off, and you can reuse the pins.
