3 point conversion on a CA
Jeremy
12-28-2002 17:13:37
I am looking at buying an Allis model "CA", it has a woods belly mower under it. Can I put a 3 point conversion on this tractor at the same time as the mower?
Mike
12-28-2002 17:58:59
 Re: 3 point conversion on a CA in reply to Jeremy, 12-28-2002 17:13:37
I think the thing you are going to run into is, the mower runs off the pto so even if you have the arms you will only be able to drag a rake or blade since the pto will be tied up? Mike
steve
12-29-2002 15:18:56
 Re: Re: 3 point conversion on a CA in reply to Mike, 12-28-2002 17:58:59
i used a splitter valve (two position) so the tractor hydraulic lever can lift either the blade or the mower, depending on which is "valved in". you are right, when you put it in pto, the mower blades always turn, even when you are using the rear blade, unless you jump the belt off.
