What Transmission oil in Allis G ??
AWB
12-29-2002 14:20:44
What is the best transmission oil to use in Allis Chalmers G transmission? Thanks.
DanD.
12-29-2002 16:34:47
 Re: What Transmission oil in Allis G ?? in reply to AWB, 12-29-2002 14:20:44
You want to use a universal trans-hydraulic oil (I would recommend this) or else #20 or #30 non-detergent oil. There are a couple of reasons for not using thick gear lube. The first is that if your G has hydraulics on it, the transmission oil is also the hydraulic oil and gear lube is too thick for hydraulics. The second is that for one of the bearings in the G tranny, it is oiled by an oil slinger that throws oil up to it from below. Thick gear lube would be hard to throw around like that.
