7060 and Leon Dozer blade
Ray
01-05-2003 16:30:19
I have a 7060 allis tractor with a 9' leon dozer blade in front the tractor works great the dozer blade works great the problem I have is the wieght of the dozer blade causes the frame rails to twist which in turn twist the motor mounts which is the timing cover then a small but steady oil leak ocurrs it can be fix which has been done before I want to know if any one has ran into a simalar problem and if so what kind of mount did the make/buy to prevent frame rails from twisting.....
e-mail me
ray
Joel
01-05-2003 17:37:26
 Re: 7060 and Leon Dozer blade in reply to Ray, 01-05-2003 16:30:19
I have a Leon blade on my 7050. All the pushing force is placed on the front of the drawbar through a large beam that runs from the lift frame of the blade and is welded to the front of the drawbar. The weight of the blade is on the front axle because it is bolted to it. Nothing is attached to the side rails. I put it on the 7050 instead of my 1486 because the front axle is heavier and the Allis has a wet clutch. I've been using it for three years now with no problems. I even built a half mile driveway with this setup, though it would have gone faster with a bull dozer.
