A-C C
barry
01-23-2003 21:13:08
My hyd.pump will not lift more than 150 lbs. orignal cylinder with new rod & seal works smoothly with no binds or leaks. refilled with jd hytrans oil.oil is still a little milky but not bad. had been sitting for 2 years before i got it & hyd. system not used for many years prior. once raised & left in hold pos. can be pushed down with about 200 lbs. what is the best place to start looking at & who has rebuild parts if needed.
Mike
01-24-2003 17:02:50
 Re: A-C C in reply to barry, 01-23-2003 21:13:08
Barry,
If you drained the fluid, the pump may have lost its prime (to some extent). Given that the fluid is milky, you more than likely still have water buildup within the reservoir and that will certainly reduce the system's efficiency. I've heard that the rebuilt pumps are rather pricey but if you find a kit, they appear to be a relatively simple device. If you need priming instructions (in one of the manuals), let me know.
Mike
