Re: 52 ac ca cranks but no start
scott
01-31-2003 04:20:25
cleaned alot more wire connections last night.have little spark,distributor cap looks pretty rough,along with wires and plugs.going today to get new ones.still waiting for my manuals,can anyone tell me what the two switches are for on steering column under amp meter.(ones a toggle switch other is a pull rod) thanks for all your help sofar
Greg Ballantyne
02-02-2003 07:08:59
 Re: Re: 52 ac ca cranks but no start in reply to scott, 01-31-2003 04:20:25
The switches sound like the same switches on my AC B. The toggle switch on mine is a kill switch, used to shut the tractor off. If you are trying to start the tractor with it in the kill position (down on my tractor) there will be no spark and the engine will not run. The second pull type switch is a headlamp/charging rate switch. The first pull position increases the charging rate. The second position out turns on the lights (if equipped).
