MAIN BEARING SHIMS- BEARING CRUSH
!!! CONFUSED !
02-03-2003 16:32:03
I have a Allis B Engine. I had my crank turned .20 and I installed a new shim set under each cap. I used plastigage under main caps and have .003 clearance. Im not sure but the crank seems a little tight but it is the same all the way around.(maybe normal) I did not check bearing crush because I used a new set of shims. Is it possible using new shims, new bearings, that bearing crush is wrong and binding crankshaft. Also should I try to get clearance from .003 to .002 or is it ok. Is there any way of testing the amount of drag( or resistance) a crank should have after it is torqued to specs.
Matt Dohm
02-04-2003 18:52:18
 Re: MAIN BEARING SHIMS- BEARING CRUSH in reply to !!! CONFUSED !!!, 02-03-2003 16:32:03
I am restoring a 1941 C Allis, s/n 11756 for an FFA tractor restoration project. Were did you get the shim kit for the bearings. No one I have talked to could find these, and there isnt an Agco dealer in my area. Any help, or info on C's would be appreciated!
Thanks in Advance
Matt D.
02-03 Cassopolis FFA
Vice President
Dave K
02-04-2003 17:18:50
Not sure on this engine but lots of engines I have seen do not have holes in the rod bolts for cotter keys or safety wire. What they should have is castilated nits or nuts with holes in them for the safety wire. Wire them together so if either trys to loosen it is also trying to tighten the other one.
Dave
Dick L
02-04-2003 15:07:30
Shoot me an email and I will explain how to file the bearings to make them fit. I can also get out a set of bearings and take some pictures on how it is done if needed.
joe 724-758-1006
02-03-2003 17:09:59
I rebuilt a ac C last year and yes getting the berrings right
is a bear first do not let the shims touch the crank 2ed do not use any lube when using the plastigage check each one adj. the shims until it is right clean and remove it go to the next the book calls for .001 to.002 .003 may cause low oil pres now after all berrings are adj. and cleaned coat with STP renistel and retorq. will spinn hard at first use saftey wire KEEP CLEAN
confused
02-03-2003 19:50:14
 Re: Re: MAIN BEARING SHIMS- BEARING CRUSH in reply to joe 724-758-1006, 02-03-2003 17:09:59
THANKS for all the info. There are no holes for the safety wire on this engine. Also no holes in rod bolts for cotter pins. This Engine is one of the last B models made in mid to late 50s. I also have a 1944 engine and it has the holes.
rudy
02-04-2003 14:35:50
 Re: Re: Re: MAIN BEARING SHIMS- BEARING CRUSH in reply to confused, 02-03-2003 19:50:14
i would a whole lot rather have them 1thou.loose than 1thou. tight u will fry your crankshaft.
DanD.
02-03-2003 16:40:40
One question. Is there any lubrication in the bearings? When you overhaul an engine, you should always put engine rebuilding grease in the bearings to provide lubrication at first start up. If the bearings are dry, I'm sure it will turn a little hard. If I remember correctly, bearing clearance in a D17 is supposed .001-.003 so it should be ok on your B. Consult a shop manual though to make sure.
Trumble
02-05-2003 16:46:00
 Re: Re: MAIN BEARING SHIMS- BEARING CRUSH in reply to DanD., 02-03-2003 16:40:40
Line bore the block, and forget the shims .....
PK Avritt
04-04-2003 06:54:51
 Re: Re: Re: MAIN BEARING SHIMS- BEARING CRUSH in reply to Trumble, 02-05-2003 16:46:00
Absolutely right. Line bore is the only way to fly.
