Need sediment bowl
Garry
02-04-2003 11:31:38
Where would be the most convient place to get a sediment bowl, latch and gasket for a 1940 AC WC? This sediment bowl is less than two inches in diameter.
Anthony G
03-17-2003 10:17:14
 Re: need sediment bowl in reply to Garry, 02-04-2003 11:31:38
I am looking for a sediment bowl for a 1948 AC Model C. I only need the bowl but if someone has the entire thing that would be ok. Thanks
Danny
02-07-2003 06:52:37
NAPA also carries them.
Keith inMT
02-05-2003 20:52:45
I just bought a brand new one at carquest
kjm
02-04-2003 20:31:00
Any local farm supply will have them in stock.
Steve in N.J.
02-04-2003 17:57:38
Gary,
I have them in stock. Drop us a line if you still need one. Steve B.
Dave K
02-04-2003 17:10:37
Saw some at Tractor Supply today.
Dave
punchie
02-04-2003 15:26:42
HI Gary
Gasket go to Lowes or Builder square , I think they are call a plumers washer ( back rubber , (they don't seem to break down from the gas). For some type of fixture. But any how 1 5/8 " or there abouts. Measure you bowl OD and get the right one, you will need to trim the inside. It cuts easy enough.
I should have a latch around if you need one( e-mail me). Normaly I get a small bolt and tap the nut to the next size, cut a grove in the bolt and bend it around the wire of the latch. But thats on working tractors not a show piece.
Have a Good One !!
Punchie
Dave (NE)
02-04-2003 14:35:02
Try Tractor Supply. I've seen them there before.
