WD REAR RIMS
ALFRED GARNER
03-28-2003 19:00:55
I JUST GOT A WD AND THE RIGHT REAR RIM AT THE SCRADER VALVE IS VERY RUSTY HAS RUSTED THRU SOME OF THE METAL AND THE TIRE IS A LITTLE LOW ON AIR/ARE THE RIMS FAIRLY EASY TO LOCATE/WOULD APPRECIATE ANY INFO/THANKS AL
JMS/MN
03-29-2003 17:19:01
 Re: WD REAR RIMS in reply to ALFRED GARNER, 03-28-2003 19:00:55
If that's the only rusty part on the rim you could cut out that area and replace it, and drill the proper size valve stem hole in another location.
acd17toy
03-28-2003 20:43:39
a good used rim for the wd is hard to find. check your local farm tire dealer they should be able to get you a new after market rim.
wdTom
03-29-2003 18:46:23
 Re: Re: WD REAR RIMS in reply to acd17toy, 03-28-2003 20:43:39
Miller Tire has rims for these tractors, think they are about $200. This is because of the spin out rails adding to the cost.
