Length for lift arms on a wd45
ksmith
04-04-2003 07:40:16
Working on setting up a 3 point on my wd45 using DB 1200 lift arms and upper supports. What I need to know is the proper length that the arms should be out the back. Center of the holes to the back of the pto shaft would be helpful. Want to make sure that it is proper for balance and proper operation of pto shaft.
Thanks in advance
Kevin
