D-12
Art
04-14-2003 08:50:18
I have a hydrolic lift pblm. Lift raises & detents fine. Will not lower with engine running,but will lower slowly w/engine off. my delima is. Is it an actator or hy/punp pblm? Any hep is appreciated. New oil,no air in line,newly rebuilt rams.Regards Athur
ShepFL
04-22-2003 20:08:37
 Re: D-12 in reply to Art, 04-14-2003 08:50:18
I have a D10 Series II and originally thought I had the same issue. Put an implement on the back then try it. You may have to crank lift arms all the way down and lift implement to connect first time.
My D10 will hold in position with engine off until I press level and then it lowers. If no implement arms always stay in position I left them in. Hope this helps.
