Re: Re: 39 B Magneto Problem
PaulT
04-18-2003 12:32:39
Thanks, Rod.
My magneto was repaired in December but I made no attempt to install it because of cold weather. Turning the rotor by hand, no spark could be found. I recently returned the mag to the shop where they turned the magneto at engine speed to check the spark from each outlet. Under these conditions the magneto seemed to work well. I suspect some problem with the impulse coupling. At the shop they talked about the possibility of a broken spring. They were able to turn the magneto by hand to identify position number 1. The shop foreman didn't think they had any replacement springs. Seeing no options, I installed the magneto but found no spark either while cranking by hand or when towing with another tractor. Paul
Tyler(WA)
04-18-2003 20:09:41
 Re: Re: Re: 39 B Magneto Problem in reply to PaulT, 04-18-2003 12:32:39
Paul,
The mag needs the impulse to fire correctly. The impulse is set to lag 30 degrees while the timing is advanced 30 degrees, resulting in fire at TDC. If the impulse is broken, there's no way for it to be timed right.
Take the impulse drive apart from the rear. They are simple enough to figure out and if the spring is broken, you'll see that right away.
