Timing an Allis G ??
Allisbob
04-22-2003 18:22:11
What is the secret in setting the timing on an Allis G? I rotated engine to get #1 cyl. on top dead center, then turned pulley timing mark to 6:00. Installed distributer, rotated ccw until points started to open. Engine makes feeble attempt to start, but backfires. What am I missing? Any help would be appreciated.
Plant Doctor
04-23-2003 04:26:46
 Re: Timing an Allis G ?? in reply to Allisbob, 04-22-2003 18:22:11
Allisbob: Your timing proceedure sounds correct. The only thing I can think of that could cause a problem would be you do not have the engine on DTC compression stroke which would make your timing off 180 degrees or you are using the wrong cylinder as #1. #1 cylinder is the cylinder to the rear of the tractor or the cylinder closest to the timing gears. The firing order on the "G" is 1, 3, 4, 2. Hope this helps. Sincerely, Plant Doctor
Plant Doctor
04-23-2003 04:30:07
 Re: Re: Timing an Allis G ?? in reply to Plant Doctor, 04-23-2003 04:26:46
Correction: DTC should read TDC.
Jack
04-22-2003 20:53:10
Are you sure you are coming up on the compression stroke? You may need to rotate one more turn.
