1948 C Distributor
S.Ammer
05-10-2003 05:29:25
I am in the process of restoring a 1948 C and am at the point where I need to know what type of lube goes in the 90 degree gear box on the lower end of the distributor (battery ignition). When I tore it down the lube looked like a plain petroleum jelly or grease. So far none of my information tells what to use. Thank you in advance for any help.
Steve
Butch(OH)
05-10-2003 12:44:19
 Re: 1948 C Distributor in reply to S.Ammer, 05-10-2003 05:29:25
Best thing to use is a 00 grade grease (semi fluid) You can check with places that sell Lubri-Plate products and ask if they can get MAG 00 in small containers. Thats what I use but have a 5 gallon bucket. Another product that would work is Lubri-Plate motor assembly grease. It comes in a big squeeze tube and is availible at NAPA. Place enough in the cavity that the gears will pick it up but don't fill it.
