48 c AC
chris
05-13-2003 22:26:51
Am having a problem when under a HEAVY drag, motor is like new , everything completely redone....like new....no corners cut, my Q again is that when under a heavy pull I think maybe the magneto may be giving out....the AC wants to run but it will "shutdown" with a slow death. Other than that , under common plowing the thing is "tough as nails". So does anyone have a clue of where I should look? And thanks for any info...there are no dumb questions "cept" the one you didn't ask.
JMS/MN
05-14-2003 21:48:13
 Re: 48 c AC in reply to chris, 05-13-2003 22:26:51
Years ago we had a WC and a C that developed the same problem: shut down while working, would not restart with starter until cooled. Would restart if pulled a few feet. Mag rebuild solved that problem.
steve
05-14-2003 15:26:55
i dont think the mag knows if you are in a heavy pull or normal running. it knows only RPM. the governor works off load, and of course the carburetor feeding fuel would be the number one guess. when it bogs down, if you back off load, does it come back up to speed? if so, i would guess the carb is not keeping up with the demand for gas.
