Hydraulic can i shut it off
Andrew Karau
05-21-2003 20:27:07
HI i was wondering if there is a way to just shut the hydraulic pump off on my wd completely
Ric Ks.
05-23-2003 14:18:47
 Re: hydraulic can i shut it off in reply to Andrew Karau, 05-21-2003 20:27:07
Depends if you want the lift off or the pump stopped - the lift lever will stop any lifting action when in the bottom position but the pump continues to run as it is dirrectly driven off a cam shaft in the tork housing. Depressing the foot clutch stops the cam but also everything else. atleast thats the way I see it.
JMS/MN
05-21-2003 22:07:47
There are two similar levers on the quandrant in front of the steering wheel on the WD. The right one is the throttle, the left one controls the hydraulic pump. When it is in the lowest position, the pump is not operating or providing pressure to the system. Beyond that, pushing in the foot clutch will keep the pump from turning.
mojo
05-21-2003 23:04:14
 Re: Re: hydraulic can i shut it off in reply to JMS/MN, 05-21-2003 22:07:47
and here i was trying to figure out which tubes to crimp!?!
mojo
05-21-2003 23:04:13
