Tranny
Andrew karau
05-22-2003 14:09:00
but why when i put it in gear does it drive for like 2 feet and then stop then have to use hand clutch there after
wdTom
05-22-2003 18:11:32
 Re: tranny in reply to Andrew karau, 05-22-2003 14:09:00
I don't really understand the problem as you are describing it. I will say that the hand clutch can drag when disengaged if the oil isn't hot and thin. Use the foot clutch to get it into gear and shift with cold oil, the hand clutch to stop and start if you wish, it will work better when the oil is warmed up from working for a while.
