5040 AC
Jerry Harrison
06-03-2003 14:36:41
What causes my diesel to run fine for 30-45 minutes and then die?If you then bleed the injection system it will start and run again for about the same length of time and then die again.I've replaced the fuel filters,fuel cap and now I'm going to replace the fuel pump.I've sprayed around all fittings and the injectors,when the engine is running,and it doesn't change the way it runs.I'm at a loss to find where it appears to be getting air in the injection system.There was no warning when it started this problem.It just started running poorly then died.Please help!!!!!
terry
06-04-2003 01:38:41
 Re: 5040 AC in reply to Jerry Harrison, 06-03-2003 14:36:41
My buddy had a case that did the same thing...new fuel pump fixed it/
