'38 B clutch pedal spring?
Tyler(WA)
06-25-2003 16:24:16
I adjusted the clutch per spec. and it works fine but where does the other end of the spring fit that connects to the cotter pin on the rod about 5-6 inches ahead of the clutch pedal?
TexMac
06-25-2003 23:42:33
 Re: '38 B clutch pedal spring? in reply to Tyler(WA), 06-25-2003 16:24:16
There are 3 holes in the pedal. One for the rod, one for the pivot shaft, and one for the spring!
John P. Martine
06-25-2003 20:14:04
I'll scan a page from my IT Manual that has an exposed view of the clutch pedal and the rod. --JPM
CHALMERSBOB
06-25-2003 19:06:24
ONE END CONNECTS TO THE LOOP IN THE COTTER PIN THAT HOLDS THE PETAL ON THE SHAFT AND THE OTHER END CONNECTS TO A COTTER PIN INSERTED THROUGH A HOLE IN THE CLUTCH ROD. GOOD LUCK WITH YOUR B. BOB
Tyler(WA)
06-25-2003 21:44:51
 Re: Re: '38 B clutch pedal spring? in reply to CHALMERSBOB, 06-25-2003 19:06:24
THAT's where that thing went. Thanks.
Alvin NE WI
06-25-2003 18:33:35
should have a hole in the clutch pedel.
