Problems with slidding real wheels in on wd
Andrew
07-06-2003 20:11:22
hi im trying to slide my rear axles in on my wd but them bolts are so tight i did everything from a lot of solvents and even heated the heck out of them and still tight help pleae
JMS/MN
07-06-2003 20:47:21
 Re: problems with slidding real wheels in on wd in reply to Andrew, 07-06-2003 20:11:22
When you loosen them, start at the top. When you tighten them, start at the bottom. Beyond that, many of them have not been moved for many years, and will be tight. You might need to remove the entire assembly from the wheel- remove the two bolts holding the casting to the wheel center, then you can take them to a vise, apply heat, etc. After that, they should work like they were designed.
T. Seifert
07-07-2003 09:27:53
 Re: Re: problems with slidding real wheels in on w in reply to JMS/MN, 07-06-2003 20:47:21
If your problem is with the eccentrics to break them loos hammer them in then out.
