Allis Chalmers WD Thompson High Crop
ACEd
09-15-2003 06:07:19
Looking for front Ag tires either 5.25-21 or 6.00-21 for a 1951 AC WD HC. So far I have found Car tires at Coker, but was told that reporduction Ag tires were now being made in Ca - but unable to confirm - any info appreciated including sources for used tires.
Bed {Ia.}
09-18-2003 12:31:49
 Re: Allis Chalmers WD Thompson High Crop in reply to ACEd, 09-15-2003 06:07:19
I think miller out in ohio has 21" tires now, but the ones I looked at, had a rear tractor type tread. I have a WD hi-crop also, what condition is your's in? serial #? email me back if you can.
ACEd
09-19-2003 11:42:31
 Re: Re: Allis Chalmers WD Thompson High Crop in reply to Bed {Ia.}, 09-18-2003 12:31:49
Unable to e-mail to you. Tractor is a 1951 s/n WD78328 with motor s/n W200527K. Its in sad shape, but I think it will run again. Tin is good with what looks like original paint, but motor stuck and water jacket cracked. Right kingpin is loose - probably a bearing - all tires rotted off, but rims intact. Has original plow lift with tool bar and discs. Fronts were 6.00-21 Goodyear, rears 13.6-36 (not 38). Also have a 1947 WC HC
Bed , Ia.
09-22-2003 19:17:38
 Re: Re: Re: Allis Chalmers WD Thompson High Crop in reply to ACEd, 09-19-2003 11:42:31
Your's is a 1951 WD? Mine is a '48. Tires seem to be a problem, I looked for about 7 years for a pair of 21's. I have a few names of tire co. that you might check. TO; ACEd from Bed E-mail?
ACEd
09-22-2003 19:57:35
 Re: Re: Re: Re: Allis Chalmers WD Thompson High Cr in reply to Bed , Ia., 09-22-2003 19:17:38
I have found truck tires at Coker and Miller, but rumored tractor fronts and Goodrich Rib Implement (3 or 5 rib) have not materialized. Would be happy to hear from you direct or anyone else on Thompson HC's. I use earthlink.net for e-mail and handle is millser
Joe(TX)
09-17-2003 09:37:15
Check with Wallace Wade in Dallas Texas. He carries sone tractor tires.
1-800-666-TYRE
1-214-688-0091
