BC Mounted plow
Aaron
09-23-2003 18:50:36
I am wondering if a rear mounted one bottom plow will fit either a B or a C. It was mounted on a B, but I only have C's. If it will fit my C, I could also use a memory refresher as to how it mounts. It's been awhile since I saw it on the B. Thanks for any help!
Eldon
09-23-2003 19:25:12
 Re: BC Mounted plow in reply to Aaron, 09-23-2003 18:50:36
The plow is the same, but the drawbar that mounts in front of and between the final drives is 12" wider for the C.
MOON
10-11-2003 10:00:37
 Re: Re: BC Mounted plow in reply to Eldon , 09-23-2003 19:25:12
DO EITHER ONE OF YOU HAVE ANY PICTURES OF A PLOW
MOUNTED ON A B MODEL. ANY INPUT WOULD BE APPRECIATED, I'M STUMPED. THE FRONT IS FAIRLY SIMPLE BUT THE BACK IS WHERE I'M HAVING PROBLEMS.
I'M NOT REAL SURE IF ALL THE PARTS ARE THERE. THANKS!!! MOON
Aaron
09-24-2003 04:58:16
Thanks for the info. Eldon. I thought the bracket looked to narrow to mount to my C.
