Re: AC model G
David Bacon
09-23-2003 20:29:50
My very first thought is clean the carburator / and or adjust it. You may consider new plugs / points etc if they are not already in good shape. The second (FIRST THING) I would consider doing is to unhook the govener linkage off the carburator. A stationary load for the engine and a assistant TO START AND OPERATE THE TRACTOR would be a must----hold the carburator shaft with your fingers while engine is working. If you can control the engine at a consistant RPM ---this will tell you it is in the govenor. ---watch the govenor linkage as you do this---Is it acting stupid or staying steady? ----I'm not sure I could understand this even if I read it myself--- In simple words you are by passing the govenor and taking the govenors place with your fingers on the throttle shaft. Good Luck Dave NE Iowa
