Shortening Rear Axle on Allis G Tractor.
AWB
09-25-2003 18:50:05
I have a 28 inch Allis G rear axle. Can it be shortened to match the other 20 inch axle which I have? Is it OK to shorten and re-weld an axle? Thanks, AWB
steve
09-26-2003 18:26:11
 Re: Shortening Rear Axle on Allis G Tractor. in reply to AWB, 09-25-2003 18:50:05
there are specialty welding rods that can weld leaf spring, axles and other hardened metal. the bigger problem is how do you plan to align the two parts and keep them straight while you weld it back together. .010 inch out of line is a lot for bearings. It can be done, but look for someone that has done it a few times.
AWB
09-27-2003 19:33:16
 Re: Re: Shortening Rear Axle on Allis G Tractor. in reply to steve, 09-26-2003 18:26:11
I have decided that trying to weld an axle is not practical, and am concerned about some possible safety issues. Since the original post I have been fortunate to find a good used axle. Thanks , AWB.
