AC 7040, 7050, 0r 7060 pros and cons?
mike b
10-14-2003 16:22:53
Just wondering if anyone had anything good or bad to say about these tractors? What is appealing to me is the dual speed pto, how well did the 540 side hold up on the high horsepower 7060? Were the engines and trannies strong, I need something with enough power to pull a five shank v-ripper but yet a 540 pto to grinder feed with. Any info is good info.
Thanks
mike B
Wally G.
10-15-2003 09:59:34
 Re: AC 7040, 7050, 0r 7060 pros and cons? in reply to mike b, 10-14-2003 16:22:53
These tractors are usually cheap to buy but once you own it it's yours until you bury it. You won't have problems with the PTO and you'll have plenty to run the feed grinder. The major drawback is the ones your looking at are fuel hogs, they will burn from 7 to 9 gals an hour. You could look for a BLACK belly 7000, 7010 or 7020 and will do damn near the same job and burn 3 to 5 gals. an hour.
