A.C. D-10
oly
04-11-1999 09:48:21
Once again i need some help. my d-10 has the 3-pt with traction booster. with the lever (for the 3-pt) in the neutral position the lift arms raise slowly all the way up , it doesn't sound like it kicks into bypass so to speak. seems that the pump is still pumping agaimst the valve. i am not real clear on this , am i. but it isn't working correctly. is something stuck? and what is it? ok, when i raise the lever, the arms should raise all the way up, then the valve detent should pop into the center position , between up and down, right. thanks brian olson
