wd vs. wd 45 pistons
slowsmoke
11-23-2003 15:01:49
When the wd was stroked to 4.5 " was the difference in the "con rod length" or the the compression height of the piston? Thanks in advance, don
Kent of SW MO
11-24-2003 07:53:48
 Re: wd vs. wd 45 pistons in reply to slowsmoke, 11-23-2003 15:01:49
NO, you put WD pistons in a WD-45 to increase the compression.
slowsmoke
11-24-2003 07:57:08
 Re: Re: wd vs. wd 45 pistons in reply to Kent of SW MO, 11-24-2003 07:53:48
that's what I said. Thanks
Ron
11-23-2003 17:55:37
The wristpin was moved up, on the WD-45..
The piston top was changed from a flat top, to a "Power Crater" design...
slowsmoke
11-24-2003 03:37:19
 Re: Re: wd vs. wd 45 pistons in reply to Ron, 11-23-2003 17:55:37
Thanks for reply. So you could put WD pistons is the "45" block and get a very high compression ratio?
