Brake Drum Puller for Allis G.
AWB
12-16-2003 18:05:43
Does anyone out there know where I can find a Brake Drum Puller for the Allis G brake drums? Or a diagram of how to build one? Thanks AWB.
Plant Doctor
12-17-2003 05:41:56
 Re: Brake Drum Puller for Allis G. in reply to AWB, 12-16-2003 18:05:43
I modified an old gear puller by welding carriage bolts to each arm. The heads of the carriage bolts were positions into the holes in the brake drums and then slid into the slots adjacent to the holes. BUT, I was never able to successfully pull a drum off without distroying it. When using the puller it would bend one side of the drum causing it to wobble or it would bend or bulge the center of drum in such way I didn't feel comfortable in reinstalling it in that condition. I was much more successful in heating the drum in the area where it contacts the axle and driving the axle out of the drum through the axle housing. I have had a few that were as difficult to install as to remove. But given my choice I would use the heating method over the puller any day. Hope this helps.
