How much a WC worth?
Aaron
01-03-2004 18:29:37
I am looking at a Allis WC. It runs and has an aftermarket 3 point how much is it worth?
Thanks
Aaron
Garry
01-05-2004 10:51:34
 Re: How much a WC worth? in reply to Aaron, 01-03-2004 18:29:37
I have one with a loader that I'm about ready to give away. I've had it a year and can't get it running. Most of the ones I've seen for sale are asking under a $1000.
Sid
01-03-2004 19:58:50
It is hard to say. I am not aware of any hydraulics on a WC. some of them had a mechanical lift which would add to the value considerably fo some peolpe. The fact it has an aftermarket 3 point makes me wonder if it is a WC or not. Look at the photo ads and you will see what some are asking. How bad do you want it is a factor. I see some for eight hundred to twelve hundred dollars they might be worth it to some but they are not to me. I might pay five hundred for on in shape to work in the field but more than likely not.
Aaron
01-03-2004 20:03:51
 Re: Re: How much a WC worth? in reply to Sid , 01-03-2004 19:58:50
He said that it has an seperate hydraulic pump that someone mounted on it to make the 3 point work.
Thanks
Aaron
sid
01-03-2004 20:10:23
 Re: Re: Re: How much a WC worth? in reply to Aaron, 01-03-2004 20:03:51
If possible to post picture I sure would like to see it. Bet there aren't many of them if it is not one of a kind.
