D15 backfires
florin
01-08-2004 18:05:57
My tractor starts good after one cranck, but when I give trottle backfires and sometimes even stalls. In the dark I can see flame comming from the top of the pipe. What do I need to do to fix this problem?
Thanks, in advance.
Tom
01-09-2004 05:32:21
 Re: D15 backfires in reply to florin, 01-08-2004 18:05:57
Since you say the dist cap, rotor, points, condensor, etc are new, bet you hav a wire crosses. Trace all plug wires in firing order to find the 2 that are wrong.
jerry
01-08-2004 20:47:37
If the carb adjustments don't work, Check timing & take a look inside the distributer and see how clean the points are and if the point spring is weak letting the points float. How good are the cap and rotor, are they corroded or clean, check for strong spark. Broken intake spring? Camshaft off 1 tooth? Just some idle suggestions. Jerry
old
01-08-2004 19:15:47
Sounds like it may be running to lean open up the main jet about half to a full turn and see if them helps if not you may need to rebulid the carb
florin
01-09-2004 04:05:52
 Re: Re: D15 backfires in reply to old, 01-08-2004 19:15:47
Thanks guys
The cap, rotor, points everything in there is new.
Old, where is the main jet on the carb, is that the L shape screw that sits on the bottom of the carb?
old
01-09-2004 06:54:30
 Re: Re: Re: D15 backfires in reply to florin, 01-09-2004 04:05:52
Yes its at the bottom of the carb just turn it out half to one turn and see if that helps, you can also use it to check to see if the carb needs rebuilt if adjusting it by turning it in say slowly with it running and it does not kill the engine then you are looking at a rebuild
