3rd gear of Allis Chalmers CA
Smith - PA
02-02-2004 17:16:52
I have a CA that works excelent except for third gear. Once in a great while I can get it into third but i have to keep my hand on it when it is in or it will pop out wheather it is under load or not. However, most of the time i cannot get it into gear. I think that it is a bent fork but i am not sure. I knowingly bought it this way and planned on fixing it. Does anyone know if i might be right. If i am wrong, what do you think it is.
Thanks for your time and help.
Smith - PA
steve
02-03-2004 15:18:48
 Re: 3rd gear of Allis Chalmers CA in reply to Smith - PA, 02-02-2004 17:16:52
there is a round cover on the right side of transmission held on by 4 bolts. take it off, it holds the forks. while off, pry the shaft with screw driver to check bearings. look at the gears to see which ones are rounded off.
old
02-02-2004 17:48:49
Well it could well be a bent fork, or it could also be a bad bearing, or a bad gear, or even a bad detent but I'd think the bent fork is most likely.
