Need Oil Seal Number.
AWB
02-07-2004 10:39:58
I need the number and manufacturer for the Inner Oil Seal on an Allis Chalmers Model G rear axle assembly. The Allis-Chalmers Parts Catalog lists it as Part # 800351. Thanks.
Russ
02-10-2004 11:35:49
 Re: Need Oil Seal Number. in reply to AWB, 02-07-2004 10:39:58
I forgot to mention that
The oil seal number i gave you was for the
oil seal that is mounted in the differential
carrier (which is connected to the transmission casing). This seal stops the oil from getting onto the brake shoes. I'm hoping this is the one you needed.
AWB
02-10-2004 15:36:56
 Re: Re: Need Oil Seal Number. in reply to Russ, 02-10-2004 11:35:49
Thanks Russ..that was exactly the seal number I needed. I really appreciated the help. Thanks, AWB
Russ
02-09-2004 13:11:50
I am in the process of replacing mine also.
The number on the one I took out is
"National 50162" and should cross reference
to other companies. I got mine at NAPA.
AWB
02-09-2004 18:22:50
 Re: Re: Need Oil Seal Number. in reply to Russ, 02-09-2004 13:11:50
Russ...Thank you for the oil seal information! AWB
AWB
02-09-2004 18:18:31
Thank you very much for sharing the oil seal manufacturer and number with me. Thanks, Again, AWB
