ac wd
art
05-03-2004 19:36:30
got wd and could not find ser# after talking to tractor people they said it was on left top(back) of brake housing WELL after removing a metal bracket that was installed to hold something?? it is so rusted that i can not read it, is there any other way to find out what year?? tractor is. thanks
J.C. IN AZ.
05-05-2004 12:56:14
 Re: ac wd in reply to art, 05-03-2004 19:36:30
WHY DON'T YOU WIRE BRUSH THE AREA OF THE NUMBER REAL GOOD THEN LIGHTLY RUB OVER THIS AREA WITH A SOAP STONE AND THEN THE NUMBERS SHOULD STAND PROUD ENOUGH THAT THEY CAN BE READ.
JMS/MN
05-05-2004 16:19:59
 Re: Re: ac wd in reply to J.C. IN AZ., 05-05-2004 12:56:14
Yeah- AC always has reason to stand proud!
JMS/MN
05-04-2004 11:25:45
Unless it is a very early WD, it is not on top of the brake housing. Look on the rear, vertical face of the left brake housing. It should begin with WD. Near the hole with the spring hooked to it.
art
05-04-2004 19:02:15
 Re: Re: ac wd in reply to JMS/MN, 05-04-2004 11:25:45
Thanks JMS/MN for the information. I checked where you said but it is badly rusted and I can not see it at all. Do you know of any other way of telling what year tractor would be? Thanks again.
JMS/MN
05-05-2004 08:17:33
 Re: Re: Re: ac wd in reply to art, 05-04-2004 19:02:15
Not reliably. You might find a cross-reference to an engine number, but engines can be changed easily. Try lightly sanding or wirebrushing the area of the serial number. Doublecheck on another tractor so you know exactly where to look on yours. If you can determine if it is 4, 5, or 6 digits it could give you an idea on year. They were made from 1948 until 1953. The operator manual has an excellent example of where to look for the number.
Dave from Eagan
05-05-2004 10:23:14
 Re: Re: Re: Re: ac wd in reply to JMS/MN, 05-05-2004 08:17:33
The axle housing between the differential and the final drive gears has a casting date on them. I believe that you read one from the front of the tractor, and one from the rear. That date may be close to the model year of the tractor.
