3 pt lift drifting
Aric
06-02-2004 19:29:05
I have purchased a WD with a hydraulic 3 pt hitch. It came with a pull behind mower, and I seem to be having a problem with the hyd drifting up. Is there a way to correct this, or is it drifting because there isn't a lot of weight on the draw bar? The control lever itself isn't moving, I tried clamping the lever in position to make sure it wasn't vibrating up, but the drawbar still drifts up. It will go back to its proper position if I stand on it, or lower the control lever a bit.
Gary W
06-08-2004 12:54:57
 Re: 3 pt lift drifting in reply to Aric, 06-02-2004 19:29:05
I, too, have a WD and was wondering if those adjustments of which you speak will just eliminate the drifting or will the lift be set at one position and not be moveable?
Gene
06-03-2004 10:27:12
Purchase an owners manual for the tractor. The manual has 4 1/2 pages of instruction, with pictures, on how to set up the hydraulic system.
Set up instructions are not very complicated. However, there are four adjusting screws.
There was a decal showing how to set up the hydraulic system on the right side of the battery box.
Owners manuals are available at the top of this forum.
