Big carb problem!
Allis Mitch Cha
06-05-2004 18:41:17
My tractor leaks gas like a race horse pissin! I got a CA i think with a a Zenith carb on it i think. The first time it started leakin is when the float fell off. It started leakin again and this time the float did not fall off. It keeps overflowing into my air cleaner causing me to have to change the oil in it constantly. I THINK this thing is a 1952 i dont know.
wdtom
06-05-2004 18:58:36
 Re: Big carb problem! in reply to Allis Mitch Chalmers, 06-05-2004 18:41:17
It sounds like you need to clean and rebuild the carburator. Take it completely apart and clean every passage with cleaner and compressed air. Put it together and back on the tractor. Have a good strainer or filter or both so dirt doesn't get into it. Dirt is likely holding the needle valve open so the float can't close it. Kits should be available if you have the model of tractor and carburator make and model if it says.
steve
06-05-2004 19:29:14
 Re: Re: Big carb problem! in reply to wdtom, 06-05-2004 18:58:36
shake the float and see if it is full of fuel. if it is it will sink and cause the problme. if it is not full of gas, then there is something stukc under the needle shut off as mentioned.
