Snap-coupler implement values
Al L. in Wisc.
06-07-2004 18:05:45
Could anyone provide values for some snap-coupler implements? Thanks is advance
Jason
06-08-2004 12:07:02
 Re: Snap-coupler implement values in reply to Al L. in Wisc., 06-07-2004 18:05:45
I am looking for the 3 pt. adapter for my Allis D14. Anyone have any suggestions? I am also looking for the attachments for a front loading setup on the same tractor.
Jim in michigan
06-08-2004 06:53:43
here they are worthless,,too many around,,I myself have 2 plows laying out back and cant sell them,,,Jim
Smitty
06-09-2004 09:43:58
 Re: Re: Snap-coupler implement values in reply to Jim in michigan, 06-08-2004 06:53:43
Hey Jim,
Like Butch, depending upon where you're located, and model of plow, I may also be interested in buying one of your plows. I'm near Grand Rapids, e-mail me if you're interested.
Thanks,
Sean
Butch
06-08-2004 07:00:58
depending on what part of MI you are in, model and price I might have interest in those plows.
Jim in michigan
06-09-2004 20:01:39
 Re: Re: Re: Snap-coupler implement values in reply to Butch, 06-08-2004 07:00:58
I will check the model.,. I just gave one to my brother last night,, turned out it was the other style connector, not snap couple,,the snap couple is a 2 bottom,, I will see if I can find the model number on it,,,Thanks,,,Jim
Sid
06-07-2004 21:29:09
Prices I have paid or have seen sell at auction in the past. Plow $75 after market grader blade $50 corn planter $15 factory grader blade $100 shop built rear mounted bale carrier $150 threepoint adapter $175-$300
Butch
06-08-2004 06:59:12
 Re: Re: Snap-coupler implement values in reply to Sid, 06-07-2004 21:29:09
$100 for an A-C made blade? You best be buying them and make yourself a killing re-selling them. Sale prices around here vary from $900, yes 900 bucks for a nice one with nice paint,factory extentions and the corners to make it a box blade, to $400 for the average one not broken up and welded, to $200 for welded up with frozen adjustments. Guess the market varies a lot
Mike (WA)
06-08-2004 12:19:21
 Re: Re: Re: Snap-coupler implement values in reply to Butch, 06-08-2004 06:59:12
I wondered if it was just a fluke, but at a sale with several AC tractors and implements, the plows were fairly cheap ($100 or so), but the AC snap coupler blade, in good shape, brought $700!
Barry Coble NC
06-07-2004 20:57:02
Could you be more specific, Al? A plow could be worth $50 while a WD45 wheel harrow with the Transport Valve hookup could be worth $500. In general, Snap-Coupler stuff is not a gold mine. But some implements are worth more than others.
Al L. in Wisc.
06-08-2004 12:58:24
 Re: Re: Snap-coupler implement values in reply to Barry Coble NC, 06-07-2004 20:57:02
Barry, This is a snap-coupler plow with no wheel. I don't know the model, but just having it sit around, I would like to get rid of it. Thanks for all the input from you guys. Yes, I have seen blades go high also.
JMS/MN
06-08-2004 13:43:38
 Re: Re: Re: Snap-coupler implement values in reply to Al L. in Wisc., 06-08-2004 12:58:24
How many bottoms? Is the standard that holds the bottom vertical like on the WD plow, or at an angle like the D serues tractors used?
AL L. in Wisc.
06-08-2004 18:30:06
 Re: Re: Re: Re: Snap-coupler implement values in reply to JMS/MN, 06-08-2004 13:43:38
JMS, I am clueless as to the different types of plows/models. This is a two bottom and has a crank to adjust angle that is rusted tight.
John (MO)
06-09-2004 13:34:18
 Re: Re: Re: Re: Re: Snap-coupler implement values in reply to AL L. in Wisc., 06-08-2004 18:30:06
50 series has a straight standard that holds the bottom. 60 series has a standard that is angled forward that holds the bottom. Bought a 60 series 3 bottom with almost new shears for $60. this spring. Saw a 4 bottom 60 series sell for $100. not quite such good shape though.
