WD45 running rough
Al in WI
06-29-2004 17:28:51
My WD45 started running rough today. It misses, pops, backfires at all speeds. I checked the fuel line and the gas flows freely. The carburator was rebuilt last year. I checked the coil and points and everything is OK there. Any ideas about whats going on here?
Rock Picker (MO)
06-30-2004 05:34:16
 Re: WD45 running rough in reply to Al in WI, 06-29-2004 17:28:51
How did you check the coil? If you have a spare lying around put it on the tractor & see if it makes a difference. I have a 60's vintage car that did exactly the same thing as you describe. It turned out to be the coil. FWIW..... ..RP
wdTom
06-29-2004 18:28:40
Do you hve dampness in the mag or distributor? water in the fuel? drain strainer and carb.
