Thanks for response - Both are Series I. Based on s/n and AC Data book, I believe 1961 for WF and 1962 for NF/LP. Motor on LP has I suffix. Motor on WF has R suffix. Someone else told me there were only 122 D15 Series I LP made and very few of those NF - maybe 30? or so - any more info would be of interest. 3 point on the WF is a snap coupler insert with 3rd point bracket behind seat - I had understood such existed from AC as option. Other has snap coupler and top link look pretty good, but attachment of lower arms cobbled up in my opinion. What is problem with power director? The LP NF slips some but I thought it is low range. I was told you could adjust by changing shim packs in Power Director clutch? but have not gotten to that - I don't use this tractor and too many other fish to fry. I had to replace rear tires on the WF (good used Goodyear 14.9-26 off a combine) as well as new manifold / exhaust to bring it back to good working status. Both are in need of cleanup and painting. I had intended to do that and try to sell individually, but running out of time and space and had an interest in buying the pair. Sounds like $5000-6000 range for the pair since Series I - with added value for LP/NF offset somewhat by cobbled 3 point and slipping PD? Still looking for any other info, but I think that helps me a lot - if I don't sell to this guy, I'll probably try to see whats up with PD clutch and lose the cobbled 3-point when I get a chance and maybe post with some photos on classifieds when I get a chance.
