wd running weird after warming up
ac
08-01-2004 12:07:35
my allis chalmers wd will start right off runs good for a couple of minutes and then it starts putting a flame out the exhaust and it can get huge at idle allmost a foot and a half long. It almost sounds like its missing and i noticed oil in the number 2 and 3 spark plug ports. And after i really use it like tractor pulling it starts making real funny noises out the exhaust almost like gargling and when i shut it off it always pops. but then again it still has its normal power so im stumpped and any help will be greatly appreciated thanks again
Steve in N.J.
08-01-2004 20:00:45
 Re: wd running weird after warming up in reply to ac , 08-01-2004 12:07:35
Sounds like the engine is getting "overfueled" to cause the flame out the exhaust. You might have the floats in the carb starting to sink allowing an overflow of fuel into the carb. I would remove the carb, take it apart and check the floats. See if they make a sloshing sound when you take them out. If they do, you need a new set of floats, and yer' back in business...
Steve/B&B Custom Circuits
