WC - water in oil
Al L. in Wisc.
08-22-2004 20:06:29
Dad was filling his '37 WC and thought it was taking a lot of water. Suddenly he saw water/oil running from the dip stick and under the tractor. Wondering where we should start to look? Was told to drop the oil pan and look up from below the engine. Thought it was all drained last fall. Thanks in advance.
Gene
08-22-2004 20:37:12
 Re: WC - water in oil in reply to Al L. in Wisc., 08-22-2004 20:06:29
Pull the valve cover and check the three frost/freeze plugs on the top of the head. If it's not leaking there pull the pan and check for leaks around the sleeves.
