allis wc puller motor ?
alliswcjr
09-05-2004 20:53:07
I have read alot of good info. 1. Use wd45 crank in stock 201. 2. Use four and eighth flat tops 3.Use big block chevy valves . ?? What size is these valves ?? Thats what I would like to know.I may have found a stuck gleaner motor may check it out some say thats the ticket. But I have the 201 already torn down.Any more info toss it out there.
A-C puller
09-07-2004 16:05:43
 Re: allis wc puller motor ? in reply to alliswcjr , 09-05-2004 20:53:07
If you want a motor that will last, forget the 201 block. They will literally split in half with much over 90 hp. Go with a combine motor or a D-17. It's pretty easy to stuff in a 6 inch stroke with a 4.5 inch bore. When you dyno tune it, find an adapter that will hook up directly to your p.t.o. gear box. You can then go up to about 115 horses before they explode. Good luck. Keep us posted on your progress. A.C.
LWD
09-06-2004 03:34:20
the chv. valves are 2.06 (intake)you will have to re cut the keeper groves. use the cam and the gov. weights from the combine that use the 45 motor. I like the M&W turbo dome pistons. If you want more,,a 5 inch crank would help, if you use a 5 inch crank you should cut .250 off the top of the pistons. there is a ring&pinon gear that would help too(not the ones from the RC)Merfeld machine,at 14723Hwy 20,Peosta Ia. 52068,,,can help you with the crank.
alliswcjr
09-06-2004 11:03:28
 Re: allis wc puller motor ? in reply to LWD, 09-06-2004 03:34:20
Thanks lwd I was thinking maybe it was 206 intake. Is the exs.160? I pull a farmall 450 in the heavy class around home . This will be my first ac build I here they are hard to beat in the 3000lb to 3500 classes.So I thought maybe I would try a little tractor.Thanks
LWD
09-07-2004 00:44:12
 Re: allis wc puller motor ? in reply to alliswcjr , 09-06-2004 11:03:28
With a 5 inch crank,I pull 6,500 in 2nd gear, tires are 18.4x28. Do you have a speed limit? you might want to try a drive pinion part no.208370. if you can find one. Dont use the pto with a 5 inch crank,,it will blow at about 75 hp.
alliswcjr
09-21-2004 05:33:08
 Re: allis wc puller motor ? in reply to LWD, 09-07-2004 00:44:12
lwd thanks for the info we some time have 3 mph class around home.That blows my mind on how much you can get out of the little 4 cy.So far I have the 201 block still to work with.I need to get it to the machine shop and have it checked the old tractor sat along time.I hope she dont split like people say.thanks everyone
