Allis B coolant leak!
Andrew Z
09-30-2004 11:12:29
First I want to thank everyone who has helped me get this tractor back together. put the spark wires back on what I think is right the cylnder closest to the front is #1 and the gas tank is #4. I put the head on with a new head gasket and pulled it around with my other tractor and the engine was sort of firing it would run for about 1 min. then stall. Adjusted all the valves and retorked the head to 60 lbs. At this point I pulled the carb. off and cleaned it hoping this was the problem. When I checked the oil I noticed it was thin and the radiator was a little low. is there anyway to stop the leak of collant into the oil? or am I doing some thing wrong. Thanks for the help!! Andrew
gregj
09-30-2004 21:08:39
 Re: Allis B coolant leak! in reply to Andrew Z, 09-30-2004 11:12:29
did it leak in the oil before you pulled the head???
