CA oil pressure
111angus
10-18-2004 15:44:48
UNable to find what the oil pressure should be on a ca, the compresson is 130 psi on all four cylinders but Ive got about 4 lbs oil pressure any info would help.
allisdan
10-19-2004 13:55:59
 Re: CA oil pressure in reply to 111angus, 10-18-2004 15:44:48
I buy my Fram C159 at TSC. Should be easy to get. I think most farm stores should have them.
Harold Sullivan
10-18-2004 21:39:33
Hi
Your same question is in the fourm arcives.
People have had the same problem for a long time.
Some filter cause a drop in oil pressure in the CA
This is an old list on Yesterday's Tractor, you can look it up if you want.
list of acceptable filters:
AC C412
AGCO Allis 240912 (corrected version)
Baldwin T300M
Fleetguard LF571
Fram C159
Hastings LF405
NAPA 1101 (old design ONLY)
WIX 51101 (old design ONLY)
If you can not find a filter on the list
I have two Fram C159 for sale
Harold
steve(ill)
10-18-2004 19:48:35
12-15 is good. some running with 5 for a long time. it iwll run with 4, but telling you it will need attention sometime. make sure the gauge is good, oil is clean and what viscosity? i use 10w30. some of the oil is blead off to the filter and then dumped back to sump. not cleaned and run thru the motor. if you have a "bad" filter that passes too much flow, it will drop the pressure. get a good filter Baldwin or Fram and install and try that with a new gauge.
111angus
10-20-2004 14:03:34
 Re: CA oil pressure in reply to steve(ill), 10-18-2004 19:48:35
Thanks for the good info.Dave
