LEAKING GAS TANK
AWC
10-18-2004 17:09:54
I HAVE AN UNSTYLED WC AND THE GAS TANK HAS A PIN HOLE LEAK BY ONE OF THE SEAMS. ALTHOUGH THE TANK SEEMS SOLID I AM CONCERNED THAT MORE LEAKS MAY SHOW UP IN THE FUTURE. IS THERE A WAY TO REPAIR THE LEAK? HOW CAN I REDO ALL OF THE SEAMS JUST TO BE ON THE SAFE SIDE? THANK YOU.
mowr
10-19-2004 18:30:16
 Re: LEAKING GAS TANK in reply to AWC, 10-18-2004 17:09:54
Be sure to only use a vented gas cap and not an automotive replacement. Automotive caps are not vented for tractor use. When installed on a tractor, danger! Somethin's gotta give!
Steve in N.J.
10-18-2004 18:54:53
AWC,
Try a local radiator shop. My radiator man did a beautiful job repairing the tank on my B which also had pinholes in the bottom. For $75. I was back in business! That was over 3 years ago. So far, so good!
Steve/B&B Custom Circuits
CH
10-18-2004 18:03:07
Look in the archives for gas tank sealing. There's about a million posts.
