Allis Model CA hydraulics
actex
10-21-2004 13:23:53
Bought an Allis CA, The hydraulic pump would not work. I dissasembeled it, cleaned it replaced gaskets and a broken spring, reassembeled. It still won't pump a drop. Help!!!!! !!!
Dick L
10-21-2004 14:07:45
 Re: Allis Model CA hydraulics in reply to actex, 10-21-2004 13:23:53
If you didn"t have a pump drawing I have placed one at the link.
I bought a CA that would not pump and one or more of the little spools were reversed. There is also a ball bearing anti blead back valve in the bottom of the pump that will keep it from loosing its prime. If it gets dirt under the ball it will not hold a prime and if it sticks closed it still will not pump.
actex
10-21-2004 14:15:36
 Re: Allis Model CA hydraulics in reply to Dick L, 10-21-2004 14:07:45
Thanks Dick, Do I have to prime the pump and if so how do I do it?
Dick L
10-21-2004 16:40:20
 Re: Allis Model CA hydraulics in reply to actex, 10-21-2004 14:15:36
You can take a plug out of the top or fill the pump thru the pressure hose going to the lift end of the cylinder. I bleed the air out of the top of the pump/valve body while priming the pump. The pump does not pump air well, not even a little.
